where can you get eccentric trailing arm bushings
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Tags: None -
While I don't have first hand experience with them, I've heard that the IE Camber/Toe kit is far superior. It allows you to adjust either/or independantly. -
It is, but the bolts they use are cheap. Just get the tabs from them and get the bolts from the dealer. They are from the rear on an E39.Originally posted by AxxeWhile I don't have first hand experience with them, I've heard that the IE Camber/Toe kit is far superior. It allows you to adjust either/or independantly.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Bimmerworld sells a set that I believe are made by Powerflex. I've had them on my track E30 for 2 1/2 years now and they have never slipped or had any other problems.
I'd stay away from the K-macs, they seem to have a history of slipping.Jeff B.
Roanoke, VA
1989 325i Track/Race prepared
2000 328Ci Daily Driver
1989 325i being restored
1987 325is being stripped for partsComment
are you sure they have rear trailing arm offsets?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
If I'm understanding correctly what your looking for, on Bimmerworld's site, under Suspension/Steering => Urethane Bushings they have listed:
E30 3 Series/318ti/Z3 Adjustable Trailing Arm Bushings
Adjust rear toe and camber
$229 for Steel coreJeff B.
Roanoke, VA
