Anyone know if these exist? I haven't been able to find any. Thanks!
Rear Trailing Arm Bearings
Tags: None -
Do you mean trailing arm bushings?
Sent from my Galaxy Nexus using Tapatalk 2 -
Why? There are several aftermarket bushings available along with OEM which last 100-200k.Comment
I was just more or less looking for the race car. The solid delrin and poly bushings are pretty tight and do not allow the trailing arm to move that freely which stiffens up the rearend the car and doesnt allow me to make softening adjustments that I would like to. Thats all.Comment
bearings
I'm kinda new to E30's and was surprised the relatively big aftermarket does not offer what the OP is referring to.
Bearing replacement bushings are very popular for old Porsches, particularly 911's
See here, maybe give Chuck Moreland at elephant a call to see if he can help. I see a real opportunity for the aftermarket in this regard. He's a decent guy.
Thanks for your responses guys, very helpful. I'm going to do something his winter. I'll update my build when I go this route.Comment
There are guys out there that cut the ends off the trailing arms where the oem bushing goes and welded a "screw in/adjustment" end with a spherical bearing.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Heim joints done rather crudely about 15 years (though in this case is was for E30 trialing arms onto an 02).
DTM courtesy of Lee http://www.s14.net/forums/showthread...-trailing-arms
In my opinion, for 99% this is largely a waste of time (cost/time doesn't justify gain).Comment
But for that 1% where every 0.01 second counts its for the win! :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Jim Levie, Huntsville, ALComment
I know BMP Design ussed to offer that serivce as seen in the picture above. They may still do it.
I personaly am looking and the IE adjustment setup with the teeth.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
