Hi I'm about to replace all my brakes soft lines ,I did some research and it appears I need a 11mm a 14mm and a 17mm flare nut wrench , is this correct?
Thank you
Soak all of the fittings in PBlaster or Kroil for one to two days before you start work. And if a fitting doesn't want to break loose, don't force it. Instead use the flame wrench. It is way to easy to strip the head of the 11mm flare nuts.
