IE BBK fitment guide
  • einstein57
    • Jun 2007
    • 10780
    310mm kit fits ESM 002 in 16x7.5 with no spacers
    fits BBS RC090 style 5s with 5mm spacer
    OZ Futura 16x9 et14 fits without spacer on the 6 piston 295mm kit, but the clearance to the bolts holding the rims together is very small.
    290 kit fit under a set of 16x7 Alpinas - NO SPACER (if you know those wheels you know the back of the spokes slope inward and can be a tight fit for bbk's)....
    www.gecoils.com
  • E30_Pare
    • 7801
    Where you have u been hiding all these wheels...
    DREWLIENTE
    1$ PShops PM me
    • SkiFree
      • Jun 2011
      • 2766
      Looks like the CCW knock-offs 16x9+25 with what appears to be the 310mm kit (though it would be nice to confirm).
      ADAMS Autosport
      • einstein57
        • Jun 2007
        • 10780
        310mm kit with 16x9 et25 CCW Reps. 10mm spacer needed for strut tube clearance.
        www.gecoils.com
        • Robert
          • Dec 2010
          • 3770
          what about 16x9 esm 002?
          • SkiFree
            • Jun 2011
            • 2766
            BBS RS's 16x7 and 16x8 running IE 310 front and rear with NO spacer required.
            ADAMS Autosport
            • aitch
              • Nov 2007
              • 94
              Does anyone know if a set of Euroweaves will fit over the IE 6 piston 295 kit? I've got the brake to wheel specs from Jeff Ireland but haven’t had time to mock these up yet. Thanks in advance.
              • fporro
                • 1858
                http://forums.bimmerforums.com/forum...neering&page=2
                those rims were 4x114 redrilled to 4x100., he's using spacers too.
                with 310mm kits you can't run bbs rs003 (30 hole) rims without a minimum of 13mm spacers.
                Maybe 34 hole rs rims will clear as they have 13" diameter, 30 rims are 12.250 dia., here's a few pics of a bbs rs003 center, there's 2x8mm spacers = 16mm inthere, see clerance?, a 13mm will be fine.
                i'm on H&R 15mm hubcentric spacers to clear fronts, rear will clear without spacers but running them to keep width equal at both ends.
                in another news, hartges 16x7.5 et25 will clear without spacers...
                salad time ... first gen ie's bbk's fit ASA 16 wheel without spacers.
                Hartge 16x7.5 et25...
                BBS RS 003 center ...
                IE first generation brakes clears ASA 16x7.5 wheels withou spacers too...
                • einstein57
                  • Jun 2007
                  • 10780
                  BMW 16x7 style 29s. 3mm spacer
                  www.gecoils.com
                  • burkey001
                    • Feb 2011
                    • 608
                    Fits 15x7 euroweaves??
                    88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                    90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                    • SkiFree
                      • Jun 2011
                      • 2766
                      E30M3 w/ IE 310mm kit on Arc8s front and rear.
                      ADAMS Autosport
                      • dmoney(AB)
                        • 1372
                        can anyone measure or make a template for the IE 310mm kit?
                        looking to see if they will fit my new wheels
                        mtech1/2jzgte/r154/275tire
                        function>form
                        • dmoney(AB)
                          • 1372
                          Anyone?
                          function>form
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Originally posted by dmoney(AB)
                            Anyone?
                            I've got a .pdf file but cant seem to attach it here. shoot me a PM with your email.
                            ADAMS Autosport
                            • dmoney(AB)
                              • 1372
                              Pm'd
                              function>form
