Mcoupe diff cover
  • erik325i
    • Jan 2005
    • 3567
    Mcoupe diff cover
    i know that some people use Mcoupe diffs in their e30s. My question is why do some of the diff covers have 2 mounting ears, and some have only one.
    The e30 just has the one mount on the diff cover, but some of the mcoupe diffs I see have 1 mount, and some have two mounts.
    Also, if I get an Mcoupe LSD that came with the cover with 2 mounts, will I just need to swap out covers with one with a single mount? or can I just not use that mount and leave it there?
    thanks.
    -Erik
  • erik325i
    • Jan 2005
    • 3567
    This is what i am talking about. Why do some have a single mount, and some have a double mount:
    • Spaz
      Crazy Canuck
      • 2276
      thanks.
      -Erik
      You need to get the one with the single mount, as for why the double mount option is there, i'm not to sure possibly a different diff? or maybe its a later verison.
      33 11 2 228 335 is the part number you want.
      Oh and gustave has a good write up on it over on his site
      http://e30m3performance.com/installs...Diff_cover.htm
      -Cam
      Cam .W '91 325is
      Spaz's 1991 Alpine White???? S52 Build Thread...
      • erik325i
        • Jan 2005
        • 3567
        Yeah, i know that I will need a single mount cover for my e30, but I am looking at buying an mcoupe LSD but it has the double mount. I assume the other diff cover will just swap on without any problems?
        Will my e30 diff cover work with the Mcoupe diff? The Mcoupe cover works on an e30 diff, so i would assume that it works the other way around too...
        • Spaz
          Crazy Canuck
          • 2276
          It should swap back without any problems, I believe.
          Cam .W '91 325is
          • Jordan
            • 12913
            AFAIK that other diff cover is from a S54 powered Coupe/M3. It will not fit a e30 diff.
            https://mtechniqueabs.com/
            • DanGillan
              • Mar 2004
              • 4061
              exactly, the proper cover is the one with one ear. make sure you get the hardware and gasket new as well.
              Dan
              • erik325i
                • Jan 2005
                • 3567
                So, are you saying that if the cover has two mounting places, the entire differential will not work, or just the cover? Will I be able to use that diff with my e30 diff cover?
                I am looking to buy a 3.23 LSD from am Mcoupe if that helps at all...
                • AdamF 88iS
                  • 2051
                  The double ear cover is from an E46.
                  Even S54 powered M Coupes use the single mounting.
                  Adam Fogg- '88 M3
                  Common sense- It's the new 'gifted'
                  • erik325i
                    • Jan 2005
                    • 3567
                    Alright it turns out that the Mcoupe LSD that I was asking about accually had only one mount. The seller just got that diff mixed up with a different one, so he thought it had the double mount... All that confusion for nothing...
                    At least now I have a new Mcoupe LSD.
                    • Jordan
                      • 12913
                      Are you sure its really a LSD?
                      Most OBDII M-Coupes that I've looked at at work do not have LSD.
                      • BimmerToad
                        • Sep 2004
                        • 1537
                        Don't all 'M cars' have LSDs? Even obd2 cars?
                        San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
                        • erik325i
                          • Jan 2005
                          • 3567
                          It should be a LSD. I spun the input shaft, and the output flanges spun the same way. I spun one output flange and the other spun the same way. If I hold onto one output flange, i cannot rotate the other one.
                          There was no tag on the diff to verify though. I just had to do the field tests...
                          • SchnellerVert
                            • Sep 2005
                            • 3948
                            Read this thread
                            • erik325i
                              • Jan 2005
                              • 3567
                              Originally posted by SchnellerVert
                              What's the point? They are talking about how the diff mounts to the chassis. Are you just confiming that the mcoupes had only the single mount, because we already figured it out.
