The car just started doing this a few days ago. Hard rights get a ticking on the left consistent with wheel speed. It only does it while turning under load. Sounds almost exactly like a rock in the tread but I checked for that. I Haven't had it apart yet but wanted some input if anyone has experienced this too.
Anyone get a ticking from the front while turning?
Tags: None -
i'd guess wheel bearing if you can't see anything rubbing. As the weight bears on that side it could make noise.'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
its your control arm. my previous e30 was making the same noise when turning, after my control arm replacement it was gone.Comment
i have no idea, that ticking noise just went away after in replaced the control arm.Comment
Well I pulled the whole side apart Saturday. Everything looks good. Under the bearing cap was spotless and there was no play. I found a small piece of blue masking tape wadded between the caliper carrier and the rotor. Removed it and no noise since. WeirdComment
You'd think it would make a ticking noise all the time. Or maybe you could only hear it when the front of the wheel was "uncovered" from the wheelwell. I once found a tiny rock in the brake pad of my Blazer, it was big enough that I still wonder how it got in there.Comment
Well I am thinking that under load of a turn the bearing has some play and it was just enough for the rotor to shift and rub it. Im still a skeptic. We shall seeComment
