I swapped an m20 into my 2002 and ran new brake lines when i swapped and now i have no pedal pressure. Ive bled the system multiple times and bought a new master cylinder and put that in then rebled them. On the pushrod of the booster it seems like there is supposed to be a shim on it according to the Haynes manual. They bleed out fine fluid goes thru, but the pedal still goes to the floor then partially comes up then i have to pull it back more for it to come all the way up. If I pump the brakes a few times sometimes i will get slight brake pressure but not enough to stop the car. Please help!
No brake pressure 69 2002
Been following your build on IG love the car.
Did you bleed the master on the bench? Do you have access to a vacuum style bleeder? Check all the new lines and make sure the fittings are tight and there is no leaks.
Goodluck I know you are trying to get that badboy to h20i -
i didnt know you had to bench bleed them, so i pulled it out again and bench bled it then tried rebleeding but nothingComment
i installed a new master after bench bleeding it but im still not getting full pressure. The rears arent gripping at all unless i pump the pedal atleast 5 or more times, and the front are grabbing. The pedal goes to its maximum and when it comes back it partially comes back but then i have to pull it back by hand and its really hard to pull back. any idea's? maybe my booster is bad? its not dented or anythingComment
