Not Sure why, but feel like I broke it...
  • duleymane///iS
    • Jun 2012
    • 153
    So I was putting on some BBS Mahle wheels I got. They look all kinds of good, I go for a test drive to break in the Falken Azenis... ANNNND... Clank clank claaaaagghhh clack.. what the hell? I didnt even get out of my parking spot... :hitler:
    When I was breaking the old lug bolts the car rolled like 3 feet and I didnt think much of it maybe the parking brake wasnt set correctly anyway, now when I drive it sounds like my rear wheel bearing is broke, the only thing getting me is when I pull the parking brake up while driving it get waaay worse and louder. What did I break? anyone?
  • duleymane///iS
    • Jun 2012
    • 153
    I am thinking parking brake shoes, or... no one say it.. wheel bearings...
    • glnr13
      • 1334
      sounds like a wheel clearance issue
      • duleymane///iS
        • Jun 2012
        • 153
        I thought so too, but I am not rubbing anywhere from what I could see at least.. :/ its dark and i was outside for 2 hours in the cold german rain.. I will check tomorrow after work
        • glnr13
          • 1334
          put your old wheels back on. if no sounds, then it's wheel clearance on the mahles.
          • duleymane///iS
            • Jun 2012
            • 153
            ok ill do that tomorrow after work, and then give another post on what happened
              • 37833
              Did you use too long of lug bolts? They could be hitting the e-brake bits.
              Grover Beach, California
              BimmerHeads.com
              • duleymane///iS
                • Jun 2012
                • 153
                Its been raining all day and I just got off work, I havent checked, but that could be a possibility I am hoping its something as simple as that! but for now I am renting a VW scirocco nice little car! E30 is my DD and only car :/
                • idanity
                  • Jun 2006
                  • 775
                  check old wheels to see if spacers are stuck on them..and re-apply them on your car if they are.
                  or.
                  pull one wheel bolt and count the threads that protrude out the back (that would be in your hub) of your old wheels.
                  then, when you get a chance to pull your new wheels, you can have a number to compare with.
                  3 pedal club
                  200,k+ club
                  cabrio club
                  port-matched- polished- purring www.BMWpark.org
                  </div>
                  linux since 1999
                  • duleymane///iS
                    • Jun 2012
                    • 153
                    THANK YOU! changed to smaller bolts no more crack crack crack, time for spacers!
