Rear Trailing Arm Bushings.
  • LowR3V'in
    • 4209
    Dumb question, but when installing poly bushings do I lube the whole thing or just the inside where the sleeve goes?
    Lubricate both with liquid soap.
    • LowR3V'in
      • 4209
      Ok thanks.
      I"m going to use ate plastilube though.
      • SkiFree
        • Jun 2011
        • 2766
        The more the better. 15k squeek free miles and counting
        ADAMS Autosport
        • LowR3V'in
          • 4209
          Drove it 3-4 miles.
          Doesn't seem to click or creek but only torqued to 30ft for some reason.
          need to retorque.
          • Vivek
            attention whore/retard/bitch
            • 6167
            Any liquid soap works? Is this better than a marine grade waterproof lubricant? I don't mind re-lubing my cab's, but I don't want to redo my TAB's.
            1992 Mauritiusblau Vert
            2011 Alpinweiss 335is coupe
            2002 540i/6 Black/Black
            2003 GSX-R 750 (RIP)
            • AndrewBird
              The Mad Scientist
              • 11898
              I don't think jlevie realized the OP was talking about poly bushings. Use grease on poly bushings so they don't squeak, use soap on rubber bushing to help press them in.
              • Vivek
                • 6167
                That's what I thought too, thank you.
