4x100 Big Brake Kit Upgrade
  • grapedrink
    • 1514
    ^^^ E30, brakes, big brake kit^^^^
    BMW 3 Series (E30) - Forged Dynalite 4 Pot - 280mm Vented Kit Specification:- Application: BMW 3 Series (E30) Caliper Type: Forged Dynalite 4 pot Mount Type: Lug Disc Size (Diam x Width): 280 x 22 Possible Wheelsize (Inches): 15 Spare Disc Part No.: 500-…
    Mods - sticky this at the top so everyone knows where to go to find kits.
    Originally posted by DaveCN
    Welcome.
    Your car is a piece of shit.
    Most of them here are, too.
  • DarkWing6
    • Apr 2004
    • 7144
    reviews on any of these?
    • grapedrink
      • 1514
      UUC- went the cheep way on calipers = over priced
      Unofficalbmw- is for the guy that doesn't have any $$
      Movit = Gold = best bang
      RPI- some good reviews but suposidly sold their last kit 6 months ago
      Rally design- Budget, probably the same area as UUC
      Comp- making my rotors
      Apex- Doesn't look that bad for the $$. Would rather try these than UUC.
      IE- They sure like to take the cars on the track. Don't like the calipers though.
      Welcome.
      • Drew325is
        • Oct 2004
        • 520
        I've got RPI Equipped's Wilwood kit. When I bought it, it was only $795 USD, and has now gone up $200 USD. RPIs service was excellent.
        For the money I paid, I think they are great. Definitely feel they are a good step up from OEM (plus they are 1.3kg lighter than OEM per side). The brackets and hats are very well made. With the price hike however, I think I'd consider something like Ireland Engineering's kit. Also, the spokes of Alpina and Schnitzer 16" wheels fowl on the calliper with the RPI kit...a friend had to get ~3mm spacers made for his car when he got the RPI kit.
        My first gripe is that RPI advertises the rotors as being .87" (22mm) wide...however they are only 20.6mm wide.
        Second gripe is that I've managed to warp the rotors, and had to have them machined. Apparently warping is fairly common with Wilwood rotors. I've read that they are not particularly well heat-treated by Wilwood, and that I may need to machine them once or twice before they settle down. While that sounds bad, considering something like AP rotors are still far more expensive, machining them is cheap and so it's a price compromise I guess. I'm not overly worried about it at this stage.
        I spoke to Wilwood about the warping, and they said the SRP rotors RPI supplied are not really suitable for my application, and that their GT series rotors are more robust...so when it comes time to replace them, I'll try the GT series.
        Another thing to keep in mind is the callipers used in this kit do not have dust seals on the pistons (I knew this before buying, and I don't think it's a really big deal...rebuild kits are cheap) and so will probably wear faster than OEM or a big name calliper.
        Finally, some things worth knowing about aftermarket brake kits in general is that they will in most cases use a solid mount multi-piston calliper, and solid mount rotor (even AP say for road kits it's easier not to have floating rotors). This means things like warping and DVT (disc variational thickness) show up VERY easily through the brake pedal or steering wheel. I like the Ireland Engineering kit for the reason it uses floating callipers. Also, a lot of the aftermarket kits use components meant for race cars (i.e. something not driven a lot, and where high maintenance is not a big deal). So don't be too surprised if they are a little more maintenance than OEM.
