Taking rotors off
  • Slicktop_serg
    • Nov 2011
    • 198
    Taking rotors off
    What size is the hex head to take off the rotor. I don't want to strip it and be screwed :-?
    91' Alpine II 318is Slick top - Totaled
    89' Lachssilber 325is - :p
  • fronton
    • Oct 2009
    • 1262
    I did this last night. I think 5mm. Don't you have a set of hex heads to try fitting before reefing on it? Also, mine came out with about 10lb of pressure at the most. just hit it with PB blaster before trying to take it out. Make sure your ebrake is off or you won't be able to remove the rotor.
    • Slicktop_serg
      • Nov 2011
      • 198
      I did but the one that fit still had a lil play in it and i awsnt sure if it was going to strip or not are you 100% its 5mm?
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        Yes, 5mm
        -Andy
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          Use a hex tool that attaches to a ratchet. If you use a standard style allen wrench you will likely strip it.
          -Andy
          • Mastrcruse
            • Sep 2005
            • 5340
            I used an Allen wrench for all four of mine yesterday and with av5 minute soak in pb blaster they came off no problem. 5mm is correct.
            • Slicktop_serg
              • Nov 2011
              • 198
              Thanks guys got it off with a 5mm, a lil bit of pb and some of that forearm muscle lol ;)
                Use anti-seize on the screws when you put the rotors on.
