Raising Motor to get at 22mm subframe CA bolts
  • ProjectCab
    • May 2012
    • 126
    got my new CA's in the mail and it seems from reading that the easiest way to get those 22mm bolts off the subframe are by raising the engine up a few inches so a socket can fit in there
    Can this be done by just removing the bottom bolts off the motor mounts and jacking it up using a block of wood to distribute the weight?
    This is my understanding, correct me if im wrong.
    thx
    You can do it that way. Lift from the A/C bracket.
