Warped rotor after two years?
  • BMWManiac
    • Dec 2010
    • 1091
    Unless you all might think it is something else, my steering wheel has a shimmy whenever apply my brakes. The car also has a tendancy to pull to the passenger side when braking.
    I replaced all my rotors and pads about two years ago....less than 20k miles with a combination of highway and town driving.
    I'm not sure if I went with OEM replacements the first time, but I know I ordered them from RMEuropean.
    If I replace the rotors, I know it is a good rule of thumb to replace the pads. Seeing as how these pads should have plenty of more life, should I just replace the front rotors, or do the pads too?
    Also, if the rotor isn't warped, could it be something else? The passenger side caliper was also replaced, so I don't think the caliper requires a rebuild at this point.
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • future rs
    • Aug 2012
    • 514
    Are they the original calipers? I know some places recommend replacing calipers on both sides of a car to match. one may have more breaking force.
    When was your last alignment?
    • WhyNot
      • May 2012
      • 363
      Originally posted by BMWManiac
      if the rotor isn't warped, could it be something else? .
      if the control arm bushings are bad and the alignment is off it can feel like that a little but its probably the rotors.
      Originally posted by der affe
      What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
      Originally posted by navid41691
      And no, I use lotion so I don't have to worry about skin irritation.
      '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
      • BMWManiac
        • Dec 2010
        • 1091
        No, the rotors/pads were replaced 2 years ago. I had an alignment at the same time, as well as overhauled the suspension....all when I bought the car
          While a warped rotor is possible (check for runout with a dial indicator) in almost all cases the cause of the vibration will be something else. Like worn tie rods, struts/shocks, wheel bearings, control arms or bushings. A pull to one side can be worn suspension parts or a problem with a caliper or line. Using pads not suitable for the driving style/conditions can result in uneven pad deposits on the rotors which will cause a vibration in the brake pedal while braking. But a vibration in the steering wheel is a suspension problem.
          • BMWManiac
            • Dec 2010
            • 1091
            Tie rods, control arms, control arm bushings, struts/shocks, sway bar/bushings, control arm to sway bar mounts, have all been replaced and are less than 2 years old. I'm thinking that the rotors/pads may not have been up to OEM standards.
            • audiquattrot
              • May 2008
              • 3836
              I'm going thru a very similar issue w my IX . Less than 2yrs ago I overhauled almost everything including brakes rotors, tie rods, sway links, shocks, springs. Rear control arm bushings. The last six months I've been getting a shimmy upon hitting the brakes at highway speeds, and attributed it to the fact that I went cheap w the rotors and pads almost 2yrs ago
              In addition I've been having a loose steering issue.
              Fast forward to last week, I installed new Oem rotors, new ebc pads, installed a new u-joint in the steering. My steering is nice and tight, but the shimmy I had upon braking was still there....if not even more amplified now.
              I'm pretty sure it's my control arms since its the only thing I haven't replaced since I bought the car. I ordered them, and hope to install nxt week. I'll update here if that has solved my issue...g/l OP
              www.instagram.com/snwmble
              #snwmble
              Current:
              '05 BMW M3 - Silver Grey/Imola Red
              '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
              '15 Mini Countryman - Blazing Red/Carbon Black
              Past:
              '01 Audi Allroad - Light Silver/Platinum Saber Black
              '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
              '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
              '90 BMW 325i - Schwarz/Tan sport *Sold*
              '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
              • BMWManiac
                • Dec 2010
                • 1091
                Wow, your issues sound exactly like mine! I'm also experiencing the loose steering issue, at least what I feel is loose....can you tell me the part you replaced?
                As far as the braking, I, too, attribute it to cheap, non OEM parts....I'll wait a bit and see what you find out.
                • audiquattrot
                  • May 2008
                  • 3836
                  i know the part # is diff between the iX and yours, but the part i replaced is #5 in this diagram There was a ton of play in this knuckle when removed.
                  i'll update here once i replace the control arms to see if that helped any
                  #snwmble
                  Current:
                  Past:
                  • Exodus_2pt0
                    • 5943
                    Pull your calipers and check pad wear on each side. Also check to see if both calipers compress without excessive resistance.
                    This sounds like one of your calipers is not doing it's job (left seized and not working properly, or right hanging up). This would also explain the brake shimmy, because one rotor is doing the work for both, causing excessive heat and warping the rotor. Personally, on a car this old, if I replace one caliper i'm replacing both.
                    Unless there is a problem with your calipers, brake rotors warp from hard driving.
                    No E30 Club
                    • BMWManiac
                      • Dec 2010
                      • 1091
                      audiquattrot, if you wouldn't mind, can I have the part number? I know you said it is different, but I looked on realoem and it is the same diagram, but they didn't have a part number listed for #5. With your part number, I can do a search for the exact verbage.
                      Exodus, I had to replace the passenger side caliper because the bleed screw was stripped. I'll look into replacing the driver side.
                      • audiquattrot
                        • May 2008
                        • 3836
                        Part # for the iX
                        32311155102
                        It wasn't a cheap part. I think i paid $150 for it new.
                        #snwmble
                        Current:
                        Past:
                        • audiquattrot
                          • May 2008
                          • 3836
                          yeah the initial diagram i posted i think was wrong. The part # i gave you is what i pulled from my order.
                          #snwmble
                          Current:
                          Past:
                          • einstein57
                            • Jun 2007
                            • 10780
                            I managed to warp new rotors in under 3000 miles. :)
                            www.gecoils.com
                              Have you proved that the rotors are warped by a dial indicator check?
