M3 Master Cylinder
  • PeaveyBassist
    • Sep 2004
    • 3511
    M3 Master Cylinder
    What does it take to use the m3 master cylinder? I know the 25mm one from the 750's work but some people say they make the pedal too stiff. The m3 one is 23mm and realoem makes it look like the fittings are the same size for the brake lines. M10's. What all does it take to use the m3 master cylinder on a late model 325i? 1991 325i 5 spd
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • rs4pro3
    • 5808
    http://e30m3performance.com/installs.../25mc/25mc.htm
    The fitting are not the same, you basically have to do the oposite of that article
    85 325e 2.7 ITB'd stroker
    • PeaveyBassist
      • Sep 2004
      • 3511
      Thanks man. So basically I would need to change the brake line that goes from the MC to the ABS pump?
      Will
      DaveCN = Old Man
      • rs4pro3
        • 5808
        Yep, You should be able to order the M3 one at the dealer for not much money.
        • PeaveyBassist
          • Sep 2004
          • 3511
          I work at a shop so we get parts from the dealer for cheap.
          This is it right?
          M3 mc
          M3 front brake line from mc -> abs pump
          Will
          DaveCN = Old Man
          • rs4pro3
            • 5808
            yep.
            • GaryE30
              • 4791
              Bringing back an old thread regarding the M3 Master Cylinder. I'm trying to put one in my 325is with e30 m3 5-lug parts and brakes. I was going to see if I could buy the line that differs from the non-m e30 with the p/n - 34 51 2 225 867. I can't find this at BMA, BavAuto, KO, and Pelican is down for me right now.
              Has anyone ever done this modification not using oem parts and what fittings did you use. I've got a brake line flaring tool, so If worst comes to worst I could just a new line, get m10 and m12 fittings then flare the ends respectively.
              Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
              • atomic
                • Jun 2007
                • 5691
                Why not just use the e32 750 25mm master instead? It is 2mm larger than the e30 m3 one and no other modifying needed... (providing you have ABS if not a simple t fitting is all that is needed)
                • GaryE30
                  • 4791
                  b/c I got this for free with the suspension swap. If someone wants to trade me a 25mm for the e30 m3 then I'd be down.
