Those with adjustable trailing arms and twelve point aircraft nuts...
  • DRTSRFR
    • May 2008
    • 1836
    Where did you source the fasteners?
    Thanks!
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    McMaster.
    • DRTSRFR
      • May 2008
      • 1836
      Hmmmm...
      Thanks,
      But aren't the IE adjusters 12 x 1.5"? ...don't see that option there.
      • AndrewBird
        The Mad Scientist
        • 11898
        1.5 is the thread pitch, not the length.
        • DRTSRFR
          • May 2008
          • 1836
          LOL...don't know why I threw the " in there.
          I brought a spare subframe to work. We're gonna do a little brainstorming on this one.
          I can't beleive there's not another solution. The design, though simple, is terrible. I would gladly pay twice as much for a useable solution. I spend $1000-1200 a year, just on back tires, and because of the goofy size(245 35 17)they're getting tough to find.
          I took my car to my alignment guy and he just laughed, told me we could have it on the rack all day if that's what it took, but that's rediculous for everyone involved.
          • E30SPDFRK
            • 5697
            Are you talking about the eccentric bolts for when you make the subframe adjustable? If so, they're e39 bolts.
            If not, forget I said anything.
            Byron
            Leichtbau
            • DRTSRFR
              • May 2008
              • 1836
              Yeah, I know about the e39 bolts.
              My setup is from Bimmerworld which, I think, are IE pieces.
              • SkiFree
                • Jun 2011
                • 2766
                Hi Mark, Its Andrew from IE. ARP should have the nuts if you wanted to go 12-point, I just don't have a part number in front of me.
                As for the design, I'll disagree to the "eccentric" design being terrible. It's simple and effective, been using it to great effect on the shop race cars for nearly 2 decades. There are other solutions out there, including the "Posi-lock" design we started making last year. We also did a number of trailing arms involving a large welded rod-end at the base of each trailing arm (this was back in the mid 90's).
                If you have the chance shoot me an email, I'll send over some info you might find helpful and/or figure out what's going on.
                ADAMS Autosport
                • nrubenstein
                  • 3148
                  I actually don't find the eccentrics all that difficult to align. Once I know things are centered, I make my alignment adjustments using toe plates so that I can lift and adjust and repeat as needed. In fact I actually find it easier to adjust the E30 rear than the pain in the ass that is the E46 rear trailing arm.
                  We just pooled together at the shop for laserstrings and a full set of toe plates. I'm definitely looking forward to that upgrade.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • DRTSRFR
                    • May 2008
                    • 1836
                    Guys, don't get me wrong...
                    I'm not complaining about the eccentrics or IE. AT ALL.
                    It's the fact that the outboard nuts are nearly impossible to get to.
                    I modified two sets of combo wrenches in different configurations. I can get a modified open end on the nut, but it's so heavily modified it hasn't the strength to move the nut. I was able to snug the nut, but, for the life of me I cannot get the nut to loosen up with that solution.
                    I also modified the box end enough to get it on the nut, but once I rotate the nut, I cannot get the wrench off of the assembly. Maybe Cab's are different, I'll have to look.
                    I can get to the nuts if I drop the subframe an inch or so, but an alignment shop isn't going to repeat that to get things right.
                    I usually do toe plate/string alignments, but this isn't a track car, and I'd like as close to perfect as possible...the reason I want it lasered.
                    Thanks for the offer Andrew, I'll shoot you an email shortly.
                    Mark
                    • nrubenstein
                      • 3148
                      Mark
                      Have you ground down the handle as well? I've gotten my wrench to the point where it isn't so bad to get it done.
                      • DRTSRFR
                        • May 2008
                        • 1836
                        Got a pic Nick?
                        I ground so much on the first attempt the handle broke.
                          Using 12-point aircraft nuts on the outboard adjusters in place of hex nuts makes it pretty easy to set toe. I use a box end wrench with a about a 30deg bend for those nuts. If the car has poly or aluminum subframe bushing, they need to be trimmed on the inner side to make more room.
                          • DRTSRFR
                            • May 2008
                            • 1836
                            Gotcha, but I can't find the nuts in 12 x 1.5. I emailed ARP to see if they have any.
                            I checked McMaster and they didn't show any metrics??
                            McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
                            • 36brua
                              • 689
                              you can always blame your kids :D
                              My CA legal M60 swap
                              The happening in our garage
