Subframe Bushing Squeak?
  • Dsun
    • Jul 2011
    • 371
    I had my subframe bushings replaced with powerflex sport and noticed a squeaking noise around 30-40 mph on drivers side, goes away at higher speeds and after awhile it goes away completely even at 30-40.
    Does anyone else have this noise or can confirm that it is my subframe causing the squeak?
    Had a smooth purchase transaction with me?
    Please share your feedback
    Did you also use poly trailing arm and/or sway bar bushings. If so I'd be more suspicious of those as the cause of the squeak. Bad sway links are also a possibility.
    • Dsun
      • Jul 2011
      • 371
      No poly RTaBs
      I got new endlinks for front and back for swabar.
      I hope its just my pily subframe bush..
