Replacing Brake Pads: Self Locking Nut
  • eskimo810
    • Nov 2011
    • 295
    I'm finishing up replacing my control arms, CABs, tie-rod ends, shocks, springs, and the last thing I'm getting to is putting on new brake pads. I would really like to have this car done by tomorrow. Is it necessary that I replace the nut that when removed allows the caliper to pivot away from the brake pad holder? Any advice would be appreciated. First time I've ever done anything brake or suspension related.
  • Vivek
    attention whore/retard/bitch
    • 6167
    The slide bolts? I'm drawing a blank...I can't think of what you're talking about on an e30. There's two slide bolts holding the caliper onto the caliper bracket and two 19mm's holding the bracket onto the spindle, right?
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • slippery
      • Nov 2011
      • 375
      I changed my pads three times, never changed those bolts.
      J
      • eskimo810
        • Nov 2011
        • 295
        J
        Thanks for correcting me, meant to say bolt.
        At the moment, I have the entire caliper hanging. So Vivek, I've removed the two bolts that attach the caliper bracket to the strut housing. I think it will be easiest to reattach those and then separate the bracket from the caliper, but I have no idea. And I have no idea where I'm going with this. Best look at it tomorrow.
        • Vivek
          • 6167
          Yep, although depending on how stuck they are a 13 and 15 wrench may not be too hard with the whole thing hanging. I don't believe there's any reason to replace those bolts unless they're damaged.
          • PNWDan
            • Feb 2011
            • 1326
            One thing I recommend is blue locktite on the carrier bolts. Those are the two that go into the knuckle not the pins the caliper slides on. I've had them come loose before.
            1987 Alpinweiß 325is
            Like the PNW E30 Local Crew Facebook page
            • eskimo810
              • Nov 2011
              • 295
              Good to know. Thanks for the information.
              • SpecM
                • Oct 2005
                • 4531
                me too
                its scary
                1989 cirrisblau-metallic 325i
                • seatown88
                  • 331
                  Locktite is should definitely be used. It is really nasty when a caliper comes off...
                  • MaxBell
                    • 1391
                    One of my basket weaves has a nice score where a caliper came lose.
                    REMEMBER: Be safe and have fun is Rule Number 1.
                    The Epic Unbuild of Clint Eastwood
                    • FLG
                      • Sep 2011
                      • 3165
                      Also good idea to lube the slider pins with high temp grease.
                      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
