Rear brake problems.
  • Link
    • May 2012
    • 834
    I recently did new rotors, pads, e brake shoes, and new fluid.
    I now have a small squeal from the driver rear wheel, and when I brake with my window down I can hear what sounds like a squeaking spring (my guess is the ebrake springs).
    What are your guesses thoughts, I am trying to avoid taking the caliper back off. I plan to pull the wheel and attempt to adjust the ebrake again and see if it goes away.
    Please give me some in put though.
    Thanks,
    Tucker
    View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724
    While possible, the parking brake is unlikely to be the cause if the noise only occurs whe you use the brakes.
    • AndrewBird
      The Mad Scientist
      • 11898
      Did you put any anti squeal compound on the backsides of the pads? Might be a simple solution.
      • Link
        • May 2012
        • 834
        Bump!
        • FLG
          • Sep 2011
          • 3165
          Might want to answer nitro's question before you bump the thread.
          What kind of pads did you use?
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • Link
            • May 2012
            • 834
            i did not put anti squeal, where would i Buy that that?
