My front end shakes really bad, only when braking, and it seriously feels like my steering wheel is gonna disassemble. I looked around here to diagnose the problem but most people's shaking seems to be at a certain speed; that is not my case. I replace controlling arms, tie rods, links, thinking that it would take care of the problem but it didn't. I'm supposed to jack my car up this afternoon so any ideas of what to look for is greatly appreciated, thanks in advance.
Front end shaking bad
Originally posted by jlevie View PostThis could be from worn out strut inserts, aggravated by a minor problem with front brakes. Worn wheel bearings are also a possibilty.1990 325is Brillantrod
1973 2002tii Verona
swap your brakes out. I had this issue recently after the rotors were turned down and some cheap pads. Under light braking there wasnt much of any vibration but under heaver braking 60 down to 15 lets say off the freeway the car would shake violently. I swapped out to some new rotors and some nice stop tech pads so far braking is perfect. Im thinking either the rotors were warped or uneven pad transfer.
Dude same thing happened to me after I came back from a mechanic. Car would shake when I was coming to a stop light, my wheels felt like they were going to fall off. Scariest feeling ever!
The ball joint nut that connects to strut housing was loose. Make sure everything's tight!
Rotors don't shake that bad unless they're just fu**ed up. It's not anything with the braking system. Something has to be loose
