Is urethane worth it?
  • Bimmer_man
    • Jan 2013
    • 1478
    I am going to be doing a extensive repair and swaps to my E30 and am curious. Are urethane mounts bushing and such worth the money for spirited driving. Keep in mine My E30 will undergo a S54 swap in a year or two I am prepping the car thats why im asking now.
    Float like a cadillac sting like a Bimmer!:)
  • Vivek
    attention whore/retard/bitch
    • 6167
    It really depends on what you want. If you want less flex and slight added performance, then yes it's worth it. For spirited driving you'll probably notice it, at least a bit. It's largely a matter of opinion, and MR 325 will completely disagree with me, while others will say that urethane is the obvious choice.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • Bimmer_man
      • Jan 2013
      • 1478
      Okay so if i put urethane throughout the whole car i do want it stiffer not like a rock i still want some comfort. Will urethane destroy a comfortable drive? I understand a lot of that comes with the coils and struts i choose but this will influence what struts and springs i get.
      • SkiFree
        • Jun 2011
        • 2766
        My opinion on a good fun street car.
        Rubber Components...
        OEM E30 M3 rubber offset control arm bushings
        OEM motor, trans, and diff mounts
        Urethane Components..
        Trailing Arm bushings
        Subframe Mounts
        ADAMS Autosport
        • ak-
          • 12422
          100% agree with SkiFree
          If you're going to drive this car day to day around the street, don't invest in the stuff that will require a better dental plan.
          OEM rubber stuff wore out in what, 15ish years? That's good enough for me + the comfort.
          1991 325iS turbo
          • Deathtoll
            • Aug 2012
            • 1285
            What SkiFree said.
            -Art
            • Bimmer_man
              • Jan 2013
              • 1478
              alrighty thank you all you saved me more money lol. Much obliged
              Now where to get the urethane bushings from?
              • ak-
                • 12422
                you can't have your cake and eat it too!
                But I got mine from here
                1991 325iS turbo
                • Bimmer_man
                  • Jan 2013
                  • 1478
                  that was supposed to be a statement oops lol i do like to do my own research i post what i cant figure out lol.
                  • Holland
                    • Nov 2008
                    • 7212
                    I disagree. Rtab's and subframe bushes will generate the most noise from poly.
                    Honestly, it's rubber or solid for me. And my car is 80% solid at this point.
                    While I don't have direct experience with poly rtabs, I do with poly subframe bushes. They generate nvh, which is no bother to me. Under hard cornering you can feel the subframe deflect as is the nature of poly, and that upsets the chassis. Solid subframe bushes increase nvh, but the benefits are tenfold.
                    Originally posted by DEV0 E30
                    • F34R
                      sLaughter
                      • 12376
                      Discover the ultimate performance upgrades for your BMW Track car. Parts for the E30, E36, E46, E9x & more. Condor has the best quality American-made engine mounts, suspension bushings, brake lines & more!
                      Everything from that guy^ let him know I sent you.
                      I think Treehouse racing control arm lollipops are amazing. I personally replaced everything with Urethane, pure love for me. Then again it is up to what you desire for ride noise/comfort.
                      Instagram: @BWeissLeather
                      Current cars:
                      ~ '87 325 M30B35 swap
                      ~ '87 535
                      ~ 01 540 Msport 6spd
                      ~ '06 X5 4.8is
                        • 37833
                        Subframe Mounts
                        My feelings as well.
                        Grover Beach, California
                        BimmerHeads.com
                        • IAmGary
                          • Apr 2012
                          • 183
                          The OEM rubber bushings can handle quite a bit of abuse and handle wear well over time, especially if they are new. Urethane is more likely to fail (tear, rip) spectacularly when it fails.
                          The community is probably as split on OEM rubber / urethane as it is on oil.
                          • F34R
                            sLaughter
                            • 12376
                            ^ The way I look at it is the intent for the cars use. I redoing my Brother's coiled vert in OE rubber with the Treehouse racing lollipops to fix caster. If the car will see an SCCA weekend every now and then with sprinted back road; I would do what Skifree mentioned.
                            If he was to do heavy SCCA like Wheelhop, myself and other members I would do sub, trailing, engine/tranny and treehouse racing control arm pops. Everything changes when you throw the car through tight turns with constant sprint to fast stops. The wear from hard braking on the engine and transmission mounts from the weight moving forward so sudden are much higher in tracking/SCCA.
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • Danny
                              • 14216
                              I redid everything with OEM rubber, except treehouse cabs, I love the feel of it. My car is a nice day cruiser/hit the track one or twice/sometimes autocrosser. It rules.
