Why is my camber off on one wheel?!? HELP
  • nickmcc92
    • Dec 2012
    • 442
    Car was in accident from previous owner.
    I thought it was the strut housing. So I replaced it from the auto yard, but camber is still off!
    Had an alignment:
    camber driver side: -3.18.
    Control arms? Or should I try a different housing?
  • nickmcc92
    • Dec 2012
    • 442
    How can I check frame damage?
    • nickmcc92
      • Dec 2012
      • 442
      And will this cause pull to the right? (Alignment guy said that)
        That doesn't sound like a control arm problem. A bent control arm causes positive camber errors. My guess is a bent strut tower or damage to the front subframe. A frame shop should be able to determine what is off and fix it.
        • nickmcc92
          • Dec 2012
          • 442
          I was thinking ball joints? But idk how that would cause camber.
          Better not be frame damage. The car is titled "junk"..
