sub-frame mount re-enforcement
  • Madhatter
    • Oct 2004
    • 966
    Originally posted by jlevie
    The only failures I've seen there involved rust damage. I wouldn't bother.
    If you are installing camber/toe adjusters, there's is no reason to use the 12mm riser bushings.
    The bushes equate to like a half degree decrease don't they? so even with the camber kit installed you are probably going to struggle to get it back to zero.
    Just a little project im working on
    - http://www.lse30.com -
