ABS toubleshooting/help
    Hello.
    A couple of friends and I are trying to track down and repair an ABS fault. I replaced the front sensors and received the ABS light. The car is a 2/89 build date.
    This is what we did:
    * Removed the ABS computer.
    * Measured resistance of each sensor at the computer connector - all 4 sensors returned a value of 1000 ohms. Which indicated a good connection to the computer.
    * While driving,without the computer, took a voltage reading from each sensor at the computer connector, 3 sensors read 2 to 2.3 volts - the right front sensor read zero. (Pins 11/21).
    * Took another reading at the computer connector of the right front sensor and it is still reading 1000 ohms.
    * Verified that the exciter ring and sensor were correctly installed.
    Any ideas are appreciated.
    Tom Rust
    A speed sensor, like a crank position sensor, can ohm out okay, but not work. To start with replace the right front sensor.
      Delete the ABS, it is a crap system
      benvideoproductions.com
      http://www.youtube.com/watch?v=617yNrOrRfo&
        Well, actually it isn't. On a street car having a working ABS can, in the right circumstances, be the difference in driving the car home with little or no damage or watching it head for a salvage yard on the back of a flat bed. On track it can be the difference between flat spotting a set of tires or meeting a wall.
