Trailing arm bushings
    Rebuilding a set of trailing arms I picked up for cheap, they were bare when I got them and I see the bushings are not symetrical. Which sides do the large shoulders go on for each bushing when pressing into the TA's? Also, should I coat them in anything before pressing in?
    I'm assuming the subframe mounts also go in from the bottom as I know they can be done while on the car.
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
    use either some green marine grease or some copper antiseize on them
      Got it, thanks. Got the bushing orientation as well.
      1990 332i, 4 door
      2017 Mazda CX-5 GT
        Good deal. I just did this earlier this week.
          For posterity.... and generally the more lube (and the stickier it is) the longer it will last without squeaking.
          ADAMS Autosport
            Perfect thanks. I'm using oem bushings though so I'm not hugely concerned with them squeaking. Why does your swaybar mount like that? Most kits I've seen use some big reinforced brackets that are drilled through the trunk floor, at least I thought they did
            1990 332i, 4 door
            2017 Mazda CX-5 GT
              It's a 2002 rear subframe, same overall concept, little different execution.
              ADAMS Autosport
                I was gonna say lol I dont think thats an e30 subframe
                  I derped hard and didnt even realize that <_<
                  1990 332i, 4 door
                  2017 Mazda CX-5 GT
