So I am under the impression that the inside trailing arm brackets need to be welded so the slots are vertical to be able to adjust camber and the outside trailing arm brackets need to be welded so the slots are horizontal to be able to adjust toe.
I got the kit in last week and so I dropped off the subframe and the correction kit at the mechanic and he welded both inside and outside brackets so that the slots were all horizontal.
Are they supposed to be all horizontal?
