front rotor wont come off
  • DrMcDave
    • 1793
    i have had an eventful 2 days here, anyway whats the best way to get a stuck rotor off. and yes the set screw is out.
  • aaron_silva
    • 1785
    BFH
    Aaron
    • e30sd
      Fistee
      • Jan 2004
      • 5517
      pneumatic asphalt jackhammer
      • SchnellerVert
        • Sep 2005
        • 3948
        Originally posted by aaron_silva
        BFH
        Aaron
        ditto
        • DrMcDave
          • 1793
          no idea what that means
          • e30Matt
            • 5077
            Big Fucking Hammer.
            • Vass325es
              • 252
              Lol!
              1987 325es. LSD 3.25 (Stock)
              1984 325e (shell)
              Goal Project:
              5 Lugs Suspension
              1996 M3 S52
              E36 6 Speed
              Rieger/Mtech Body Kits
              Z3 Steering Rack
              • Old'n'Slow
                • 436
                A dab of anti-seize behind the new rotor, yes?
                They're right, though...get a RLY BFH
                • uflnuceng
                  • Apr 2005
                  • 1049
                  I like using a cheap propane tourch around where the rotor meets the bearing, then beating it with a BFH.
                  crowbar... BFH... torch... the 3 most important tools you'll ever have and some of the cheapest to get.
                  • Axxe
                    • Aug 2004
                    • 3355
                    I love my airhammer. 10 second zap and everything comes off. Beat the BFH method, but still the BFH works if you don't have air tools.
                    Keep it slideways!!
                    • asubimmer
                      • 6482
                      BFH's save the day!!!!!!!!
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        Put one lug bolt on slightly. Get behind it and wack it and turn as you hit. Just.... keep hittin ;) The lug on it will keep the rotor from FLYING off when it breaks loose.
                        Will
                        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                        Welcome e30 (brilliantrot '90 325is) 12/23/06
                        DaveCN = Old Man
                        My signature picture was taken by ME! Not by anyone else!
                        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                        • AdamF 88iS
                          • 2051
                          Scrub the hub with a wire brush then put a little anti-seize on it to prevent the new one from getting stuck.
                          Adam Fogg- '88 M3
                          Common sense- It's the new 'gifted'
                          • Brew
                            • 3060
                            Probably not a great idea to use a torch on the hub/bearing. I do brakes almost every day at work and I've never had a rotor that won't come off with a couple good whacks with a hammer.
                            Definitely thread a lug bolt in a bit to keep the rotor from flying.
                            '91 318is
                            • DanGillan
                              • Mar 2004
                              • 4061
                              dont be a waffleswaffleswaffleswaffleswaffles. hit the fucking thing. YOU cant hit the rotor hard enough to damage anything besides yourself. so whack away.
                              Dan
