Question about s50 master cyl & booster ?!?!
  • roznic
    • Mar 2013
    • 2876
    I am doing a 5 lug swap on my 91 325i with all front susp and brakes from 98 m3 and rear 318ti trailing arms and e36 328 calipers. I have access to a '95 m3 master cylinder and booster.
    Has anyone ever installed it on a e30 ?!?!
    1. If so, should I do only the master cylinder or booster as well??
    2. If so, is there much mods involved if any??
    3. What if I get rid of the booster completely, cons and pros??
    Or should I just get an e32 master and be done with it??
    Appreciate your feedback in advance!!
    Thx, Nick.
    I guess, looking for the IX booster, anybody??
  • roznic
    • Mar 2013
    • 2876
    anybody??
    • hooken m
      • 1537
      you can also try posting this in the 5 lug section.
      1. as far as i know you can put a e36 MC on an e30 IX booster.
      2. an IX booster is a direct bolt on. with the e36 booster you will more than likely need to make some modifications, but dont quote me on that.
      3. i dont think you wanna get rid of the booster cause braking will become a complete bitch cause it wont be assisted at all, which means you have to actually dig into the brake pedal to stop.
      good luck,
      Amin
      Originally posted by evandael
      a car is a car. call it a dildo, i'd still drive the hell out of it.
      • roznic
        • Mar 2013
        • 2876
        good luck,
        Amin
        hmm, u give even more food for thought... but thx anyways!
        • FLG
          • Sep 2011
          • 3165
          If you go no booster you will need to find a different master cylinder. I think massive lee sells a kit. It will take a bit more pedal pressure but will stop just as well.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • bubbajan21
            • 1962
            The E36 M3 MC bolts right onto the ix booster, I run it in my car.
            • roznic
              • Mar 2013
              • 2876
              So, how is IX booster, is it bolt on as well, any mods?? since you already've done it... how is your braking overall?!?
              thx, in advance
              • roznic
                • Mar 2013
                • 2876
                • Roysneon
                  • 4505
                  Is your car 24v swapped? If not just use stock booster and e30M3 master. Sorry if you mentioned it was swapped, it's been a rough night.
                  Originally posted by mbonanni
                  I am a pursit now.
                  • Roysneon
                    • 4505
                    What is your brake setup and what diameter is the e36 master? Are e36M and non-m the same?
                    I am a pursit now.
                    • roznic
                      • Mar 2013
                      • 2876
                      up!!!!
                      looking for a good IX booster now....anybody??!?!
                      • amcink
                        • 788
                        E32 bosster and MC with remote reservior ftw! Just got mine set up at pnp $25 since it is 1/2 of for memorial day
                        • roznic
                          • Mar 2013
                          • 2876
                          Sorry man, come again?? u got booster & mc for 25??
                          • amcink
                            • 788
                            Yes! At pick n pull this weekend is 50% off
                            • roznic
                              • Mar 2013
                              • 2876
                              ahh, nothing is near me...
