axle differences
  • dougie30
    • Apr 2012
    • 1708
    axle differences
    ok so i want to buy new axles and rear hubs but the ones for my 86 (with abs) are 260$ a piece. i found some for a 1990 (with abs) for 110$ a piece. are there differences between the two?
    and if i buy the ones for a 1990 should i get a rear hub for a 1990?
    also thought is say that while doing this im changing my rear sub frame and trailing arms with one form a 1988 ix (with abs)
    so should all of this go together correctly as along as it is all abs specific?
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • SpecM
    • Oct 2005
    • 4531
    all rear six-cylinder w/abs axles are the same
    1989 cirrisblau-metallic 325i
    • dougie30
      • Apr 2012
      • 1708
      THANK YOU :up:
      what about the hubs? should i get ones for the 1990 or it dosnt matter?
        The hubs are the same, like the axles.
        • dougie30
          • Apr 2012
          • 1708
          thanks guys
          • dougie30
            • Apr 2012
            • 1708
            a guy in town is parting a 1990 318is i read that these axles will work is this true??
              • 37829
              Yes the 318iS axles are the same as well.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • dougie30
                • Apr 2012
                • 1708
                appreciate the feed back
