brake issues after 24v swap
  • ClausE30
    • Sep 2011
    • 981
    Hey guys,
    I am near the end of my s52 swap and my brakes are the only thing that seems to be of problem, maybe?.. I have installed a 944 booster, actually the 2nd one so far, thinking that the first one had issues.
    Basically, I can't seem to quickly brake when needed, the pedal is firm and it takes more leg muscle than stock setup.. Car has sat for 3ish months during swap.. I have bled the system of all air I believe, fluid seems to leave the front pass caliper extremely slow compared to others (idk if a problem?).. Just looking for some help troubleshooting!
    Thanks!!
    91 Alpinweiss2 318is OBD2 S52
  • ajhostetter
    • Apr 2013
    • 1218
    I have a 320i booster in my swap. Brakes are more wooden than stock. Just takes some getting used to. Not sure about the fluid running slowly. I've never noticed anything like that during bleeding....
    2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
    • ClausE30
      • Sep 2011
      • 981
      hmm, ive drove 100 miles on the swap so far.. and the brakes are terrible, instant rock hard pedal.. This is my 2nd Porsche 944 booster, can i really have two go bad on me?
      • Danny
        • 14216
        Do some squats. I have an e21 booster and the brakes are awesome.
        • ClausE30
          • Sep 2011
          • 981
          i guess so.. but really, i have what feels like no power brakes so I'm assuming thats not standard with the 944 booster?
          • E30_fiend
            • Apr 2006
            • 7348
            You need to check the booster adjusting rod. If its too tight, you will have brake drag. If its too loose, you will have a hard pedal.
            Taylor
            • ClausE30
              • Sep 2011
              • 981
              is that on the master side or the pedal side?
              • nokincy
                • Feb 2012
                • 302
                Pedal side. Adjust at the clevis.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Make sure the pistons in the calipers are not stuck. Check for rust on the rotors; a sure sign the calipers are stuck. Could be collapsed brake hose as well. They deteriorate and swell on the inside. If you are getting plenty of fluid out of the bleeders though, the lines are likely fine.
