Where to buy E30 rear backing plates?
  • MaxBell
    • 1391
    My rear handbrakes is (obviously) torn through the backing plate, so I want to replace them.
    I can't seem to find them! (I'm in Canada) I looked on PelicanParts and AutoPartsWay.com. Where else could they be?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
  • Cephas
    • Apr 2012
    • 878
    Bavauto? They were on rhere several years ago when I needed them.
    Edit. They are there.
      • 37832
      Part numbers:
      34211162061
      34211162062
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • MaxBell
        • 1391
        Do I have to remove the rear hub to take these out?
          Yes. Which means you'll need to replace the bearings.
          • MaxBell
            • 1391
            That sounds like a srs job...
            *sigh* PUT IT ON THE LIST!!
            • Viking445
              • Apr 2013
              • 99
              Got mine from ecstuning.
              89 320i Touring/M52 Swap w 4.10 Gears/K&N intake/Catback Exhaust/KW coils/Wilwood brakes/Azev A 16x7.5F 16x9R 215/40/16 F&R
              • Andy.B
                • Sep 2011
                • 1650
                I know this is probably too late for the OP, but a great trick to get your car back on the road with working ebrakes until you have the time/motivation to replace the backing plate is to get a hardware from a different car that has retaining cups (and longer pins), and use them instead. I usually just bring the stock pin in, and look through the hardware kits until I find one that works. Lots of cars out there are set up that way from the factory, so although it might not be bmw spec, it is perfectly safe and durable. When I worked at a used car dealership, we used to use that method all the time. It is how one of my rears is currently set up (I believe I used some gm sedan hardware kit), and although I have new backing plates in a box, I am going to let it go until I need to take it all apart to replace the wheel bearings.
