SLR angle kit
  • jalopi
    • 2370
    SLR angle kit
    Hey bros,
    Trying to get some input on SLRs' angle kit for the e30. I've seen wisefabs' angle kit on cars before and how the camber gets so extreme that they have to include a "strut relocater" in the kit to correct it.
    Just wondering if the SLR kit is the same way or what... not as much info on the web about theirs.
  • jalopi
    • 2370
    Bamp for 50 views, yet no feedback.
    • jalopi
      • 2370
      Come on now, SOMEONE has to have some feedback about the kit
      • IronFreak
        • Dec 2012
        • 3702
        Ask FLG, He just installed it on his car.
        Instagram @rebellionforge
        • e30 gangsta
          • 3877
          SLR in my opinion is a nicer kit. They have to use a strut relocater because of all the extra track the kit gives you. I personally like the slr kit because you can still use aftermarket top hats ( camber adjustable ) and still have usable angle. Sean love the person that designs these kits its very knowledgeable. Id suggest emailing him.
          Trusted by top racing and drifting teams worldwide. Angle kits, Coilovers, Sway Bars, Camber Plates, Caster, Lock Kits, Drifting Kits, Toe Plates, Wheel Hubs, Steering Kits, Drifting Suspension, Subframe Brace, Control Arms, Lollipops, Coilover Conversion, Lower Control Arms, Steering Rack Stops, Lock Limiters, Tie Rod
          • jalopi
            • 2370
            I ordered the half kit (no arms) from him a few weeks ago, waiting for it to come in. Just hope that it comes in soon - first event of the year coming up on the 29th.
            BTW, the half kit is great if you've already got e46 arms - comes with everything to make you go 'super dorifto' for $550. pretty reasonable imo.
            • FLG
              • Sep 2011
              • 3165
              The wise fab does relocate the top mount to help camber.
              2 problems I've seen,
              First, it's not legal.
              Second, I've seen guys with issues with the strut hitting the inner fender area due to the relocation and having to lower the top further down to clear things.
              Sent from my SCH-I545 using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • jalopi
                • 2370
                That top mount is kinda sketchy anyway. Based off of what I saw when installing my camber plates the wisefab top mount won't work with stock struts anyway. I think they were made with a smaller diameter spring/coilover setup in mind.... that's the only way I can see them working anyway
                • FLG
                  • Sep 2011
                  • 3165
                  Yep, and even then my bud had clearance issues
                  • FLG
                    • Sep 2011
                    • 3165
                    Hey there.
                    Lol
                    So 16x7s clear at zero offset
                    The 16x8.25 xxr shouldn't be an issue, bought a 40 sidewall tire to be safe.
                    • jalopi
                      • 2370
                      Just got my super drifto 1/2 kit in today, gonna start working on it in a little while.
                      This is the one where you remove the stock outer BJs and install the BJ sleeve supplied by SLR. The only thing I'm not sure of is how to install the sleeve. The adapters came in with the sleeves installed with the ridge down, as in you'd press the sleeve in from the bottom of the control arm. My question is that should it press in from the top of the control arm? So that it can't potentially fall out? There's no groove or anything for a snap ring.
                      • FLG
                        • Sep 2011
                        • 3165
                        Got a pic? Bottom makes more sense, it'll always be under load from the suspension.
                        • jalopi
                          • 2370
                          So I got the BJs pressed out and went to position the bearing case... and it slid in, with slight pressure, by hand about 95% of the way. Initially I thought this was 100% and was like... 'da fuq' and hit it with a socket a few times. Installed the arm on the car - as soon as the BJ got a bit of pressure the case would pop out. Pulled it back off and tried putting it in the press - turns out 100% was 90-95. Broke the little 'ridge' on the sleeve by pressing a bit too far, but goddamn that bitch is in there now. Installed the arm again, put the car on the ground and jumped on the diving board a few times with a friend (about 350ish lbs total). No movement from the sleeve.
                          The angle... the difference is insane. Didn't get an exact measurement, but it looks like my 16x8 et0's have about 1/4-1/2" before hitting the arm. It was dark in the garage, I'll take a measurement tomorrow.
                          • FLG
                            • Sep 2011
                            • 3165
                            Glad it worked out. Yeah should be perfect with that, might need shorter tires if your not running 45s or 40s
                            • jalopi
                              • 2370
                              Ok so I went to the first event of the year and found the answer to my wheel clearance question...
                              If you
                              A. Have 8" wheels, 0 offset
                              B. Have rack spacers in addition to the angle kit
                              and
                              C. Have e46 control arms
                              you will not have enough clearance. I knew something was binding up but I kept on killing it anyway... when I checked to see what the tire was hitting later I found that the inside of my wheels had been hitting/grinding the control arm. Notched the arm by about 1/8-1/4" or so.
                              Definitely need spacers and more caster.
