Damaged FCAB Lollipop bolt hole
  • ksjdan
    • Jul 2012
    • 330
    Hey guys,
    I ran into some troubles while replacing some suspension parts. One of the lollipop bolt broke off, then extractor broke, failed drilling it out and the bolt hole piece is loose now. Anyone ran into this problem before? What steps can I take to fix this problem?
    Here is a stock image of the fcab bolt
    My 1990 325is Build Thread
  • Madhatter
    • Oct 2004
    • 966
    probably only thing you can do is drill the hole out a little bigger and tap a new (larger) thread.
    Just a little project im working on
    - http://www.lse30.com -
    • ksjdan
      • Jul 2012
      • 330
      I thought about that, but I dont know if its possible since the lollipop has a certain size.
      • iansane
        • 1342
        Nutsert?
        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
        • jalopi
          • 2370
          Helicoil?
          • Madhatter
            • Oct 2004
            • 966
            Make the hole in the mount larger too, it has a lot of plate steel. Only problem I could think of is if there is enough metal on the underside of the rail to take the hole out larger. I can't remember if it was a nut or a plate on the inside.
            • ksjdan
              • Jul 2012
              • 330
              Originally posted by iansane
              Nutsert?
              This was what I was thinking about, but didn't know if it existed or knew the name of it.
              • Madhatter
                • Oct 2004
                • 966
                I probably wouldn't trust it on a piece of suspension.
