Turner Brake Overhaul Kit
  • markd248
    • Apr 2013
    • 108
    I need new pads and rotors for my 91 318i and saw that Turner Motorsports had a full overhaul kit. I was wondering what people's opinions were on this kit and if they had any recommendations for new pads & rotors.
    I daily the car and do some spirited driving, but I don't have any autox or track time planned.
    Thanks in advance
  • oliver.r
    • Mar 2012
    • 3839
    I got it for my m3, the axxis pads are legit, go with solid rotors for street driving, make sur eyou get the caliper rebuild kit and while youre in there replace the guides with the copper ones the offer
    • AndrewBird
      The Mad Scientist
      • 11898
      Stock Brembo blanks are as good as any and cheap. Lots of info here on pads, just search.
      I've noticed most of the time that "kits" like this tend to be higher priced than just buying the individual components from various places. You tend to pay for it being a kit and not having to piece it together yourself.
      • oliver.r
        • Mar 2012
        • 3839
        make sure you replace your bleeder screws also
        • markd248
          • Apr 2013
          • 108
          This may be a stupid question, but can the 318i's caliper accept a vented rotors? I read on the e30zone wiki that they cant, but elsewhere I'm seeing that I can.
          For reference, I'm looking at getting vented Power Stop rotors, here: http://www.jcwhitney.com/powerstop-p...7213y1991g2j1#
          and here's where e30zone says it won't match up: http://www.e30zone.net/e30zonewiki/i...p/Brakes#Discs
          Just wanted to double check before ordering them, Thanks in advance
          • oliver.r
            • Mar 2012
            • 3839
            the width is what matter, unless your tracking the car and driving it hard ALL THE TIME vented rotors are not a good investment
            • Thizzelle
              • 4422
              318 does accept vented, i have vented on all my cars like a bawse. I STOP ON DIMES AND FOR DIMES
              "I wanna see da boat movie"
              "I got a tree on my house"
              • AndrewBird
                The Mad Scientist
                • 11898
                Only early model 318's used solid rotors. Since you have a 91, you wanted vented rotors.
                • oliver.r
                  • Mar 2012
                  • 3839
                  Shit I'm thinking slotted, sorry OP
                  • Gertech
                    • Jul 2013
                    • 180
                    I ordered their front and rear kit when I redid my brakes. Came with nice Zimmerman blanks and Axxis pads. So far so good! I didn't do the copper guides like oliver.r mentioned, but I'm probably going to go back in and take care of that over the winter.
                    • Roysneon
                      • 4505
                      Brass guides, but whatever. They really do feel better, due to my shitty wierd master cylinder and brake caliper combination I had pretty soft feeling brakes until I installed them on the front of the car. Just be aware that you have to lube them up occasionally.
                      Inb4 lube joke.
                      Originally posted by mbonanni
                      I am a pursit now.
                      • Gertech
                        • Jul 2013
                        • 180
                        Brass...yeah that's what I meant. Does your car have ATE front calipers? Mine has Girling...do they work for them or just ATE? I'll definitely be getting them for the rear but I'm still not sure about the front.
                        Do you use regular brake grease for lube?
                        • 85bim
                          • Jan 2011
                          • 92
                          That kit is vented front and solid rear. Just in case you didn't notice...
                          I am also interested in putting vented rotors on my e30 do they just bolt up without any issues if I have solid rotors now?
                          • Subtle
                            • Jul 2013
                            • 289
                            I have Girling's as well and I didnt check the fitment before ordering apparently they don't fit Girling Calipers :(
                            '91 318is w/ M50B25TU
                            • Roysneon
                              • 4505
                              If you're still wondering...
                              If you have an early 318i with m10 you'll have solid fronts and rears but if you want vented fronts you need the calipers from a 325 or later 318i/is and the rotors. They bolt up to the smaller diameter strut housings.
                              I am a pursit now.
