M3 Soild CAB's
  • aaron_silva
    • 1785
    M3 Soild CAB's
    Is there any trick to getting these suckers on besides warm water and soap? Am I too weak or something?
    Thanks
    Aaron
  • PeaveyBassist
    • Sep 2004
    • 3511
    Lube em up and push REAL hard. Only way to get em on AFAIK.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • aaron_silva
      • 1785
      Holy fuck I need to start working out or something. Those things are HARD to get on.
      Thanks for the help.
      Aaron
      • Kip
        • Feb 2006
        • 183
        Use a hydraulic press. Make sure to use a collar that hits the inner metal sleeve so you don't tear them. Put middle ball joint end on bottom of press, place new bushing and bracket on control arm, hold the whole thing steady, and there ya' go. Did mine this weekend, freakin sucked, handles great now.
        88 325is FOR SALE
        89 325i FOR SALE
        95 LR Disco
        98 Volvo V70XC -FS!
        25' of oil-stained driveway
        Travel Kit:
        M4, FS 92, Mk19, 998
        • golde30
          • 11464
          hes putting them on the car, not pressing them into the lollipops...
          some1 said lube em up? what kinda lube is to be used, i have to put mine on also. PS: dont use soap, when it dries it will act like adhesive and cause it to bind.
          IG: @Baye30
          • kencopperwheat
            King of Kegstands
            • 14396
            The rubber ones are supposed to grip the control arm.
            Originally posted by Gruelius
            • golde30
              • 11464
              in that case, use soap. hehe.
              IG: @Baye30
              • Jand3rson
                • 37587
                Exactly. You don't want any movement in them at all. That's why they're rubber, so the center grips the arm, and the rest of the bushing flexes.
                • MarkH
                  • Jun 2005
                  • 65
                  I used some soapy water as a lube, started the CAB on by hand, took a deep socket just large enough to fit over the control arm end, and a couple of gentle taps and it was all the way on.
                  • aaron_silva
                    • 1785
                    Thanks for the input, I was able to get them on with a 1 - 2 - 3 shove!
                    Aaron
                    • redcarbon
                      • Apr 2005
                      • 213
                      good to hear you got them on. after 3 weeks of a suspension rebuild, the CABs were the last thing to go on and I could not get them on for the life of me with a little soap and water. I was getting frustrated. So finally I loaded it up with like 5 times more soap and they slipped right on. Just let them dry up real well before driving on them if you used a lot of soap.
                      318is -gone-
