brake drag/parking brake/wheel bearing?
  • e30fish
    • Oct 2009
    • 332
    I'm having a brake squeal exactly like a brake wear indicator tab squeal, the ones built into brake pads to tell u it's time to change pads. It's coming from the rear brakes on 40mph or slower stops. I've taken apart the pads, they are more than 75%, greased all the brake parts and still have annoying squeal. I didn't rebuild the pistons, didn't go that far.
    I don't have any wear issues, don't have any vibrations leading to wheel bearings. Their is no play in the back wheels as well. The only thing I can think of is something to do with the parking brake dragging? Should I take off the rotors and inspect the parking brake? Anyone have a similar issue, any insights or suggestions if it is the parking brake?
  • oliver.r
    • Mar 2012
    • 3839
    I had the same thing happen, ended up being the wheel bearing, it progressively got worse
    • e30fish
      • Oct 2009
      • 332
      It probably is.....my puny arms probably can't get any play out the wheels and it's probably early stages
      • oliver.r
        • Mar 2012
        • 3839
        when I was driving at highway speed I couldn't hear it but in traffic it was obvious, all of a sudden it just started squealing really loud
          To tell if the noise is from the calipers or something else, lightly apply the brakes when squeal occurs. If it goes away, the brake pads are dragging.
          • e30fish
            • Oct 2009
            • 332
            It squeals under braking. When I let off the pedal it stops. Only occasionally it will squeal for alittle after I let off the brake pedal.
            • AndrewBird
              The Mad Scientist
              • 11898
              Do you put anti-squeal paste or grease on the back of the pads? Often times the "squeal" you here is actually the brake pad vibrating at high frequency against the piston. Greasing them stops this.
              • e30fish
                • Oct 2009
                • 332
                Yes, I greased everything when I took them apart. I initially thought this was my problem
