Control Arm Bracket Help with Sizes and Dimenssions .
  • Sindako
    • Nov 2012
    • 116
    Hello E30 Mates .
    I Am Planning To Manufacture My Own Lower Strut For My E30 .
    I have all The Dimensions For It , But the Only Dimension Left Is The Space Between The Control Arm Bracket Nuts .
    The Strut Bar From The Left Outside Nut to the right outside nut is 412x2
    which means it's 824 as full length . and the center of it is 412mm
    but I need to know how many mm is there between the bracket nuts .
    Check The Photo Attached To Know What Dimensions Do I need .
    I will Post Photos Of Manufacturing when I make it .
    I already Made My Own Rear Strut Bar . and it was a Schmiedmann Replica .
    really amazing on Cornering .
    Anyways If any of you know what I need please help .
    between A & B . How Many MM . Exactly . Or Maybe You Can Give me the Length between outside (Z) to outside (X) . and I will do the other dimensions .
    Cheers .
    Get a few new lollipops and measure the spacing. Then average the results.
    • Sindako
      • Nov 2012
      • 116
      What does that suppose to mean ???
      I can buy new brackets , but why buy if I already have them installed .
      I need To Manufacture it first , because When I install it I will use my friend garage .
