Re-using front wheel bearings
  • Dirtboy
    • 458
    I know pulling the front hubs usually leaves the inner race stuck to the spindle. Question is- Could you re-install them after you remove them?
    Hear me out- The hubs are new; I installed them about 4 months ago. They've got to be removed to do some work on the struts. I really don't want to buy another set of hubs since these ones have barely 2500 miles on them.
    What do ya'll think?
    Nürburgring info
  • E30_Pare
    • 7801
    You can reuse the hubs as long as you don't damage them removing the inner race.
    DREWLIENTE
    1$ PShops PM me
    • Madhatter
      • Oct 2004
      • 966
      if you removed them with a slide hammer, you run the risk of damaging the bearing itself. Id replace them.
      Just a little project im working on
      - http://www.lse30.com -
      • Dirtboy
        • 458
        I used a hub puller the last time I changed them.
        Nürburgring info
          • 37833
          As long as it comes apart properly you can definitely re-use it. I've done it before.
          Grover Beach, California
          BimmerHeads.com
          • kalib0y
            • Dec 2004
            • 3620
            Agreed with above but just get new if possible
            95 7.1L 16V E36 M3
            Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
            LIKE my Facebook Page! CLICK HERE
            • AndrewBird
              The Mad Scientist
              • 11898
              What work are you doing to the struts that needs the hubs removed?
              • Dirtboy
                • 458
                Sending them in to GC to get shortened, braced, and powder coated.
                Nürburgring info
                • Madhatter
                  • Oct 2004
                  • 966
                  just leave the hubs attached. Only problem might be if you want to remove the dust shield, otherwise I can't see what problem they would cause if you leave them attached.
                  • Dirtboy
                    • 458
                    Problem solved. Hubs came off easily and in one piece.
                    Nürburgring info
