Posting here for more chance of a reply.
1991 318
I'm having trouble lining up the sub frame with the body.
With one side on, the other side just almost lines up it's a like 1-2~mm off to the side to lining up.
My old *front* subframe was cracked (clear across the weld, sides were only thing holding) and the 'triangle' (mount sits on it) was bent inwards (towards front of car). So I pulled out a used sub frame from a 150k 318.
Removal of my rack/sub was fine. I bolted up my rack/control arms/swaybar, I can't seem to get both sides mounted up, I can get one side fine but not both.
It's a sure PITA to try and get each side lined up and the steering column into the knuckle.
Since then I've tried:
-Having one side loosely on and trying to line up the other side.
-removed motor mount to see if it was bad and causing excess pressure on the frame and causing the issue; nope.
-a crazy zip tie contraction to try and see if using them to ratchet the rack closer to the side it needs to go; nada. it did help great keeping it in that place though.
What am I missing??
I unbolted the steering knuckle from the top one, does it make it easier doing the bottom one?
I am going to remove the struts off tomorrow, they and the damn brake shield constantly get in the way.
Thanks in advance for any help!
1991 318
What am I missing??
