e30 brake fluid green?
  • goldfishe666
    • Feb 2014
    • 107
    Hey guys. I just bought an e30 recently its a 1990. I checked the brake fluid reservoir today and found some green fluid on top. This is odd. I am wondering if the previous owner accidentally poured a little coolant in there or something. Is this bad?
    I was hoping to get some new brake lines and flush the fluid. I have never seen green fluid inside the brake reservoir before. Any suggestions?
    The brakes pretty soft, I was assuming there could be air in the system. Now I see green and think it may be coolant.
    You could be right. In any case I'd flush the brake system a couple of times. A pressure bleeder makes that a trivial task. Push a measured 250cc through one rear caliper, and 150cc through every other caliper.
    • danix
      • Jan 2014
      • 151
      Green like antifreeze green or streaks of green? If they had ATE super blue fluid in there and some moisture got in, I could see that being partially green.
      1988 325iC SOLD
      1985 524td 49k
