Subframe Camber Adjustments
Will I be able to acquire the proper camber adjustments from just the weld in adjusters? I ask because I've already completely refreshed my subframe with AKG Poly bushings everywhere and wasn't lowering the car at the time so I wasn't looking at riser bushings or anything fancy.
Also did the brake lines while I was back there :pComment
I don't see why not? Figure with the eccentric adjusters give you a certain range of adjustment, you can locate the plate to your advantage. With the "posi-locks" Your looking at nearly double the initial adjustment range so initial plate position isn't as important.Comment
The most important adjustment on a road oriented car is for toe. You need to be able to dial back to standard settings to minimize inside tire wear.Comment
