Rear Suspension Bushing Question
  • Victor_PR
    • Jun 2011
    • 296
    Hi;
    I need to replace my trailing arm and sub-frame bushings.
    RealOEM gives me 2 part numbers for the TABs:
    1) 33-32-9-058-822 Eccentric
    2) 33-32-9-061-945
    Which one should I get? What's the advantage eccentric vs normal?
    Thanks!
    Victor
    Rides...
    E30 325i - 1990
    F30 328i - 2014 (DD)
    F25 X3 - 2016 (Family car)
    1974 - 2002 (The ruler of the stable) SOLD
    Eccentric trailing arm bushings are use to correct rear camber/toe issues. The disadvantage of them is that the tend to drive out of adjustment. If the car needs camber/toe correction, weld in camber/toe adjusters are far better.
    • Victor_PR
      • Jun 2011
      • 296
      Thanks Jlevie;
      I'm going with the normal ones then since I don't have any camber/toe issues.
      Regards,
      Victor
      Rides...
      E30 325i - 1990
      • Quinthirty
        • Mar 2012
        • 318
        Who carries this weld-in types of camber / toe adjusters? I think I need one. I suppose they can work on a stock suspension. Do you really need to reinforce the rear sub-frame even if you don't track?
