akg rear subframe bushing question
  • mr.vang
    • 4371
    How come the shaft inside the akg bushing doesn't go all the way down like the OEM one? Is it suppose to be like this? Does the subframe bolt have something to do with it?
  • mr2peak
    • 2388
    Maybe you can find it here
    http://www.akgmotorsport.com/gallery...ollection&id=2
    Drive it hard. Maintain it well.
    A Topless Memorandum
    • mr.vang
      • 4371
      Nothing on the rear subframe bushing. I'm trying to find a diy, but no luck with answering my own question.
      • mr2peak
        • 2388
        Post pics, I'm cloudy on what you mean
        • mr.vang
          • 4371
          Tapatalk was being lame, won't let me open the app unless someone message me. Picture is up
          Sent from my Nexus 4 using Tapatalk 4
          • mr.vang
            • 4371
            I went ahead and tight everything up and went for a drive, the clunking noise from the rear is still there. Look like I will need a new driveshaft now.
            • mr.vang
              • 4371
              Anyone?
              • mr.vang
                • 4371
                Bump
                • mr2peak
                  • 2388
                  Those bushings look fine.
                  What is this new noise? You should't need a new driveshaft. What else did you touch? Did you torque it all down correctly?
                  • mr.vang
                    • 4371
                    So the akg bushing are design that way? I was just carious since the stock one has its center piece goes all the way down. All bolts and nuts are torque within spec.
                    About the noise, It was there before I swap the subframe bushing. After searching for answer, many told me it was the subframe bushing. After the bushing swap, the clunking noise is still there. After further searching, someone on bimmerfest posted a video of a bad u joint and he was having the same noise from the rear.
                    • Wh33lhop
                      • 11705
                      What's the noise? Also, do you have a poly diff bushing or is it old and decrepit?
                      paint sucks
                      • mr.vang
                        • 4371
                        Its a clunking noise from the rear. The diff bushing is the stock solid rubber.
