Front wheel bearings
  • aaron_tupper
    • Oct 2013
    • 134
    If I took my hubs off could I have a place that sells new sealed bearings press them out and press new ones in the hubs? So im not paying $240 for two front wheel bearings.
  • efficient
    • Feb 2012
    • 3312
    If your bearings are beat most likely theyll just pop out or you can use a puller to get them out. Also to pop them in they just go in. Thats from my experience though. But I think new bearings cost around 80 for the fronts.
      • 37832
      Meyle are only about $80 a side.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • IronFreak
        • Dec 2012
        • 3702
        if I'm not mistaken....the front hub/bearing is a one piece unit that has to be replaced as one. it's not separate like the trailing arms.
        Instagram @rebellionforge
        • Wh33lhop
          • 11705
          You aren't mistaken. OP, try finding the bearing separate of the hub.
          paint sucks
          • aaron_tupper
            • Oct 2013
            • 134
            Thnaks guys
            • AndrewBird
              The Mad Scientist
              • 11898
              BluntTech has just the bearings for $28 each. Hub and bearing already together are $53 each.
