Rear Camber Kit Install
  • SmokeyMcPotholes
    • Mar 2014
    • 23
    Has anyone else installed "D Hole" style toe and camber adjusting bushing set ups in the trailing arms of an e30? Seems like to do it correctly I'd have to lower the crossmember that cradles the dif.
    It's my first day
  • drumad
    • Aug 2009
    • 1700
    It'd make the job a hell of a lot easier. Removing that subframe isn't too difficult.
    Worth doing it to replace all the bushings anyways.
    Plus it's nice to get intimate with her underside.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • SmokeyMcPotholes
      • Mar 2014
      • 23
      Oh, I'm all about gettin intimate with her.
      • SmokeyMcPotholes
        • Mar 2014
        • 23
        my issue is, I can't put the bolt through the right side of the bushing when the flange of the inner bush faces the outside of the trling arm. Its ridiculously confusing... but its not possible without lowering the subframe. So if I do all that then put it back together again and now I can't adjust the bolt head cuz there's no room to rotate it? That's why I ask if anyone's installed one.
        It's my first day
        • SmokeyMcPotholes
          • Mar 2014
          • 23
          This drawing would be of the Driver's side tr arm inside installation.
          It's my first day
          • SmokeyMcPotholes
            • Mar 2014
            • 23
            GD signature..
            • jrobie79
              • Mar 2006
              • 2526
              where in mass you located? I installed on on my e30...I did drop the subframe tho
              1991 318i ---- 308K - retired
              • mr2peak
                • 2388
                You will have to drop the subframe, sorry. Might as well do braided brake lines while you're in there. If you want to swap diffs, this is also the correct time to do that. Oh, and subframe bushings because the subframe will be out, and trust me, you don't want to do that more often than you absolutely have to.
                Save the money, do it all at once the right way. It's certainly worth it.
                Drive it hard. Maintain it well.
                A Topless Memorandum
                • SmokeyMcPotholes
                  • Mar 2014
                  • 23
                  So the adjustment is still possible once the subframe is back in place, but it must be real close quarters trying to turn those outer bolt heads. Or did either of you change the direction of the through bolt? J I'm in the Tri Town up by the old Searstown Mall. And Sir, I would love to replace all that (though my existing parts are in good working order) but I've reached my budget for now. My parts pile is decent. More stuff will trickle in but no more big spends (hopefully) til next year.
                  • drumad
                    • Aug 2009
                    • 1700
                    Any competent alignment shop should still be capable of turning them. I know mine doesn't have that problem and I also modified the mounts to be slotted.
                    Well the real problem with these adjustment bolts is that they don't always hold their position.
                    2008 335i - n54b30
                    1991 318i - m52b28
                    • SmokeyMcPotholes
                      • Mar 2014
                      • 23
                      I wondered about them staying put as well...
                      It's my first day
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        You guys seem to be talking about two separate things. OP, you seem to be talking about eccentric bushings, while drumad is talking about eccentric adjuster bolts and plates.
                        The bolts are known to come loose, but eccentric bushings should stay in place.
                        • SkiFree
                          • Jun 2011
                          • 2766
                          The eccentric bushings are known even more so for coming loose.
                          ADAMS Autosport
                          • jrobie79
                            • Mar 2006
                            • 2526
                            thejlevie had a good solution to keeping the weld in adjusters locked in place, IIRC he fabricated an arm with a socket welded to it (same size as the eccentric bolt) and locked it in place. I'm not sure on the details, perhaps you could PM him about it.
                            Also IE makes a "lock-style" serrated adjuster, not sure on the reputation on those style for loosening over time though.
                            • SmokeyMcPotholes
                              • Mar 2014
                              • 23
                              The eccentric bushing I'm using has serrated ends and the nut is serrated as well. As it sits now, I didn't lower the subframe. I assembled the outer set ups with the nut and bolt facing opposite the install instructions... when I get it to a lift on alignment day I'll assemble them correctly.
