How hard is
  • Lake
    • Apr 2013
    • 177
    How hard is
    It to change a wheel bearing? I believe I need a new one and don't wanna start something I can't finish.
    Do I need any special tools, or machines?
    Car: 1985 BMW 325e
    If you know of any tutorials please link them.
    Thank you,:-P
    Originally posted by Ty13r
    if you scream while doing it you'll gain extra power. worth a try.
  • ButtJuice
    • Dec 2009
    • 2609
    Search, topic has been covered in the DIY section on how to replace both front, and rear, wheel bearings.
    1991 318is - Sold
    1986 325 - Sold
    Instagram - Lamoursum
    • DesertBMW
      • Aug 2011
      • 1039
      easy if you have the right tools. Usually no puller is required.
        A front wheel bearing is pretty easy to change. You might need a puller for the inner race. The rear wheel bearings are easy with a B90 tool set and a real pain otherwise.
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          ^what he said
          • e30_302
            • Sep 2013
            • 453
            Front's are easy, rear can be a real PITA, even with the right tool. I had more trouble getting the axle back in the hub than anything else. Harbor Freight sells a FWD bearing kit part #66829 that makes it easy to get the bearing out.
            • SkiFree
              • Jun 2011
              • 2766
              If you have to ask........
              ADAMS Autosport
                I have seen a BMW special tool that makes getting the half shafts back in a piece of cake, but I have no idea where you'd get one now. And I have learned to very carefully examine the splines on the half shafts for any evidence of galling. If I find that, new half shafts and hubs will be used.
                Heating the hub to about 250F and chilling the half shaft spines in LN2 (or in an alcohol & dry ice mixture) helps. The one thing that you cannot do without damaging the half shafts is to drive them in.
                • Dakotademon7
                  • Jan 2014
                  • 446
                  I did my front one and it was super easy but I have been doing auto repair from the age 13.
                  sigpichttp://www.germanaudiospecialties.com/
                  1986 325es :early:
