UGH! sometimes I miss stuff as I look over my car. today I figured would be a good day to change out all of the bushings in the rear, no problems took 3 hrs for all of them. My tires in the rear had worn uneven (inside edge) the bushing were all toast. I attributed the wear to those.
But, when I pulled off the passenger trailing arm, I noticed a dent on the bottom about 2" long, 1/4" deep on the bottom of the arm, almost centered between the arm mounts. Po must have hit something...
SO, is there a way I can check the arm for straightness? I would imagine that it will be a problem, the last alignment showed both rears equally bad, so maybe not. I don't know I left it off for now. Don't want to put a bad arm back on... argh! I just keep finding more retarded problems with everything I touch. As a bonus, I saved the rear for last, so this most likely is the last stupid thing I'll find wrong...
