rear wheels are stuck
  • rikaro
    • Nov 2012
    • 123
    Hope I can get some help from you guys.
    I was changing my wheels today and after I drop it back on the ground, the car doesn't want to move forward or backward. I jacked the car up and the wheels still rotate, clockwise and counterclockwise but for about 180 degrees and it doesn't turn anymore. This applies for both wheels.
    Also I tried putting in one of the bolts on the wheels and it doesn't seemed to go all the way in. I was wondering if there's something wrong behind the rotor.
    Any input would be great guys. This is my daily driver so hopefully I can get it back on the road asap :)
  • Bglad
    • Jul 2010
    • 562
    Sounds like your wheel studs are too long and are hitting something.
    • rikaro
      • Nov 2012
      • 123
      oh you might be right. i had spacers on before and the car probably came with longer studs.
      • AndrewBird
        The Mad Scientist
        • 11898
        Yup, definitely too long. They will interfere with the parking brake.
        • rikaro
          • Nov 2012
          • 123
          got it fixed! Thanks guys
          • e30crazie
            • Feb 2013
            • 858
            This happened to me about 10 years ago with an 84 318i that I bought, it came with 15x8 BBS wheels and had longer bolts in the front. I rotated all the tires and did the brakes and brake cylinders, when I reassembled I could not get the rear wheels to turn but half way. Then is when I noticed that the longer studs where placed in the wrong wheel. Drove me nuts for hours till I finally figured it put. Freaking hilarious... Thank god you got it going and fixed.
            I am not sick, I am twisted. Sick makes it sound like there is a cure.
            1991 318is Diamantschwarz Metallic
            1989 325i Alpine White
            • KIRIEIW
              • Dec 2012
              • 3385
              Good info to know, happy everything worked out.
              1992 e34 Touring- S50 Swap
              1992 325i-S50 Swap (SOLD)
              1991
