Front subframe bolt hole stripped?
  • clint-o-matic
    • 36
    I pulled the rear most front subframe bolt to install some IE sway bar brackets/bushings. Pretty sure I over tightened on reassembly as the bolt just spins now. The bolt seems fine so I'm assuming it's the threads inside the body? Should I just run the same size tap in there? What other options do I have? Thx.
    A HeliCoil comes to mind.
    • clint-o-matic
      • 36
      Cool. Thx
