Looking for a DIY to replace the brake master cylinder in a 1991 318i.
Girling master cylinder DIY?
I am not sick, I am twisted. Sick makes it sound like there is a cure.
1991 318is Diamantschwarz Metallic
1989 325i Alpine White -
Well there you go... The rest is pretty easy. Its literally nuts and then the 2 hard lines. If you can empty the reservoir do it as its easier to remove the inner nut if not its going to be harder but it can still be done. When you install it done put the reservoir in until after you finish tightening everything. Anyway... Hope I was of some help.
Thank youI am not sick, I am twisted. Sick makes it sound like there is a cure.
1989 325i Alpine WhiteComment
