Reusing rear wheel bearings
  • gordie
    • Dec 2013
    • 15
    New rear wheel bearings fitted and now I want remove the 4 stud hubs and fit euro 323ti hubs I picked up. The arms jave been welded with Z3M type cross pieces and sway bar reinforcements. Dont want to replace zero mileage bearings. Anyone done this?
    I would advise against trying to reuse the bearings. Pulling the hub means putting a lot of pressure on the inner race that it was never intended to see. There is a good chance of damaging the bearing and you may not find out until later.
      • 37832
      I've pulled and reinstalled a new bearing. No issues whatsoever. I have the proper SIR tool though.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • jalopi
        • 2370
        Lol put them back on, you'll be fine.
        • rcsoundn1
          • Nov 2012
          • 3361
          Any info on the tool you actually used?
